Old 03-07-2003, 08:32 AM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Default Zoop or 200MPH Polish?
Do you guys know if you can use these products on surfaces that will get hot? I should be taking delivery of my motor in the next two weeks and since I can't do anything with it until I get the car, I was going to polish all the aluminum on the motor. In addition to the valve covers, pulleys, etc., I would also like to polish the heads, waterpump and manifold. Will either of these products take the heat?
p.s. I did look at the Ozona Report that Ron posted the link to, but he only tested at temps. up to 275, I imagine that heads will get a lot hotter than that.
Thanks for your help.
Mike
Replica is not a dirty word.
