Old 03-08-2003, 02:20 PM
Jim Downard Jim Downard is offline
Cobra Make, Engine: Classic Roadsters, 393 stroker, Tremec 3550, about 425 hp, MDA GT40 289
Another little bit of info. Have you thought of going with the Edelbrock power up kit. It would be a Cam, Heads, Intake, and Carb. Would be good for about 400+ hp and no machine work on the block. You would only have to have the block cleaned for a rebuild, possibly line bore the mains, have the crank checked, and put her back togethe with new bearings. It would be a minimal outlay for maximum hp. Of course, I like those cast iron Roush 200's. Weight isn't a concern enough of mine to go the extra for aluminum heads. To me Cast iron = nearly indestructible. (CHEAPER TOO!) I've seen in the jeg's catalogue, Roush heads about $350 each assembled. Then get your own cam and a good intake and carb. BAM, more that enough hp to burn up those expensive tires.
hey, this is all just food for thought.
Jim Downard
