Old 03-09-2003, 07:27 AM
Lowell W Lowell W is offline
Club Cobra Member
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
I'm curious: Is the cam or a lifter (s) damaged similar to the case of the guy in the ERA buildup story? If so, aren't you concerned about bearing damage? Seems to me you'd at least want to pull the caps and check the bearing shells if there's been some crap circulating thru the motor, no?
