Neutral
Well, the 4.0 is very small comparing to the 5.0, 5.8 or the 7.0. However, the Lexus V8 DOHC is a very effecient engine with turbos, this engine has the capability to make monsterous power. There have been many cases that 1UZFE made over 1500-2700 rwhp. We are talking about stock block. I dont think the American V8 can handle that type of punishment.
Secondly, the Lexus V8 is incrediblely durable. Its is very common for this engine to have 400-600k miles life span. Reliability? This engine is the best of the best from Japan. This engine is the bigger brother of the Supra TT (2JZ-GTE). If you think the supra TT make killer power, you should see this V8.
Someday, i would like to put this engine with two T3 turbos into the Factory Five Replica.
With only 2200 lbs, how much torque do u need to spin the tires? Not too much.
I had americans and I know.
-01 MDX (N/A Negative 18 PSI)
-98 Supercharged Cobra (Built Motor with 15 PSI around 500 rwhp & 6 Speed (For Sale)
-90 LS400 TT (Twin T3 Ball Bearing 8 PSI with Methanol Injection 324.5 rwhp & 324.7 rwtq)
-Looking for a 92 Pearl White SC400 with high miles (Single Turbo or Supercharged Project)
