Re: pulling cam with engine in car
Steve,
I just pulled my cam last week with the engine in the car. I'm stepping down a notch on the cam... Depending on what chassis # you have, its possible. One is more difficult than the other. I had to pull the radiator for sure, undo the motor mounts, and tilt the engine upwards. I wanted to see if it could be done. Next time, I would probably consider pulling the motor but I refused to pull my tunnel out this time. Good Luck.
Duane
