Old 03-10-2003, 12:29 AM
Bart Carter Bart Carter is offline
Cobra Make, Engine: Levy Racing built FFR w/351W
Default Re: 302 vs. 351 empty block weights
All in all, maybe a 100 lb difference bewteen the basic
289-302 vs. 351's after all.
Closer to 65 lbs.
Further reductions from earlier 289/302:
Aluminum heads -45 lbs.
Aluminum water pump -7 lbs.
Aluminum intake -18 lbs.
Mini Starter -6 lbs.
Aluminum flywheel -19 lbs.
Tubular headers -14 lbs.
Toploader to T5 -36 lbs.
Been there, done that, took measurments along the way.
