Thread: DVSF Forum!
Old 03-16-2003, 06:14 PM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
Hi Brent,
Here's an example from this board:
I go to the member galleries and ask to see all this user's photos - in this case I use you
Netscape sees:
http://www.clubcobra.com/photopost/s...ype=2&si=Brent Mills&cat=500&sort=1&ppuser=9454
Notice the blank space between "Brent" and "Mills". When Netscape sees that it says
"The parameter is incorrect. "
and dies - or at least it refuses to accept that this URL is valid - because it contains a blank space. Most software has an option to substitute the %20 character (the hex value for a space, the ASCII 32 character equivalent) and then Netscape is happy!
If I recall, you've done this %20 substitution elsewhere, just a few left in the gallery as far as I can tell.
Not a biggie if it requires too much work to fix!
Regards,
Tom
