Holley, electric choke, no bigger than 650cfm (not a street avenger series either). Will need to know projected compression, and what CC the heads are, along with which type of screw in studs you'll need (size of thread going in to heads, size of stud itself). Push rod length will depend on which cam (standard or roller) and rocker style (ditto) your planning to use, your going to have to make an educated guess on these, then find an adjustable push rod to get the accurate (IE: correct) lengths dialed in......Get me the specs, and I'll get you what I can....Cam wise, I prefer the non roller rocker hydraulic units that emulate the older style 289HiPo cams.....Crane makes a really nice unit, but I need to know what type of compression we are going to have (I suggest no more than 9:8:1 so you can still run pump gasoline)........
Will await your detailed response........
Sincerely,
Bill S.
