  #21 (permalink)
Old 03-21-2003, 12:15 PM
KobraKarl's Avatar
KobraKarl KobraKarl is offline
Larger the diameter of the piston= greater volume to surface area = less heat,shorter stroke= less friction =less heat.
comparable volume with a smaller bore=longer stroke=more friction=more heat, smaller piston=more surface area per volume= more heat.
larger piston surface area=more effeicient conversion of energy/lbs per square inch of thrust.
or something like that
Foolish consistancy is the hobgoblin of tiny minds
