Scott:
Running pressure that is too high will reduce the tire's footprint and adhesion. Because these cars are light and the tires big you do not need to run high pressures.
I've been running my SPF at 20 PSI all around with no problems. If I went to the track I would add 4 to 5 pounds.
Bob
