  #26 (permalink)
Old 03-26-2003, 11:25 AM
Pete C's Avatar
Pete C Pete C is offline
Cobra Make, Engine: ERA 427 SC #004 (Original ERA?)
Wayne,
Are the studs straight? Will the pin fit into the 5th hole when free of the adapter? The first time I mounted my trigo wheels it was a bear. After driving on them, the studs realigned and removal and remount was a piece of cake. I did make a problem for myself once when I re torqued the pins. Due to the anti seize, the drive slipped out of the head of the pin and flared the end slightly, but enough so that remount was a problem. Did you flare the head while you torqued it in place? If so, it will be difficult to insert the pin in the hole even when not mounted on the studs.
Cheers, Pete
Drive it like you stole it!
