I am having a 1973 351C 2V rebuilt. I'm looking for some advice on parts/upgrades. This will be going into a 73 Mach 1. Only requirement is that it be able to run on pump gas The more power the better.
Current setup:
73 351C .030 over not sure on CR of pistons yet most likely 8.5-9.0
Stock open chamber 2V heads
Offy dual plane intake
Old school Holly Carb (4150?)
Headers 3" collector
C6 tranny
3.89 rear end
Flywheel, torque convertor, starter, and
oil/water pumps will be replaced.
Need advice on:
heads - keep current, go Aussie 2V, or?
cam kit
intake
carb preferably Holley
torque convertor
roller rockers?
etc...
The guy that has the engine right now only does top end stuff. He will not work on the bottom end, so I will have to take it somewhere else if anything needs/should be changed.
Thanks for any help.
