If you want to see any of this on a live car, give me a shout. I am in the finishing stages. Not everything I have done may be 100% correct, so you can look at it and we can work together. You are definately missing parts. There are several spacers that go on the axel. One is fairly thick and about 1" long, then there are two, one on each side of the spherical bearing on the shock to allow it to swivel. On the top, there should be a spot for the coil overs to mount between. You will again need spacers on each side of the spherical bearing. I hope they did not forget to put the mounts there for you, I thought they were standard.
Ron, you guys been sniffing to much fiberglass resin, is that what really happened? I am still waiting on some seats, Karen said she had a ticket in. I am not in a hurry, but will be needing them eventually. The more I wait, the more likely I am to try to fit these high backs in and modify the tonnaue cover that I had to have!
Tom
