Old 03-29-2003, 08:09 AM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Steve, although I do not have photos of this installation, I have a set of these adapters running on the same heads you mention and the owner is as happy as a clam. These adapters will work on ANY small block Ford head that has standard valve train geometry (no canted valves or rocker girdles). You can see in the above photos that I am running Crane 1.7 ratio roller rockers with no interferenceon a set of GT40P heads. The Edelbrock heads supposedly have the same valve train setup. All I know is that the guy who bought the adapters has a 392 stroker motor with Edelbrock RPM heads and Crane roller rockers and told me that the adapters work perfectly.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
