Thread: Piston Choice
Old 03-30-2003, 11:37 AM
gman gman is offline
Cobra Make, Engine: A&C 460
Question Piston Choice
Need some help. I'm getting ready to send things out to get balanced and I can't make up my mind on which pistons to use. I have a set of Keith Black flat tops and a set of trw L2404 dished pistons. I have a C9VE block, Dove heads,Torker II intake, and comp cams hydraulic w/ 230dur 530 lift. If I fiqured right the KB's put the compression over 11. This will be street driven an must make the 3 hr ride to the fling. A'm I going to regret the higher comp? Thanks Gman
