Details:
- selected light weight Brembo 14" rotor
- designed custom aluminium top hat that would locate the rotor in the best spot and fit the XJ bolt pattern, etc.
- design and build a custom Cr Moly Steel bracket to locate the caliper in the correct spot relative to the rotor.
- upgraded to all aircraft quality hardware to hold on rotor and for caliper and bracket.
Will only work on 17" and larger wheels (may for 16" but I doubt it).
