Old 03-30-2003, 01:12 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
The problem was easily solved by calling Phil Schmidt at PS Engineering. See my photo gallery.
Actually to affect offset you need to place the wheel center where it needs to be. You can't remove material from the back of a (any) knock off wheel and affect offset as the center of the wheel also has a bearing surface with the hub.
Trigo makes one offset, good for coffee tables.. Not so good for custom applications.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
