Old 04-01-2003, 03:15 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Remove the gold colored steel inverse flare fitting from the fuel bowl inlet (center hung float bowls only), replace it with the blue anodized aluminum fitting that has a -6 male flare fitting coming out of it. Use 3/8" stainless hardline, tube nuts and a flaring tool. Go from the log to the fuel bowls with stainless hardline only, it looks a whole lot better than rubber line or braided stainless. Besides, some racing bodies don't allow rubber fuel line on top of the engine.
