Thread: Brake lines
Old 04-05-2003, 11:25 PM
fw209's Avatar
fw209 fw209 is offline
Cobra Make, Engine: It WAS a B & B 306, T-5, narrowed 9" - 4:11... Hope to replace it soon.
Question Brake lines
OK!! The suspension is in and temp rear tires on.. Brakes are in the AM.. BUT..... What size lines do I use? The book shows 1/4" the packing list says 3/16"? All of the fittings on the master are reduced to 3/16" as well as the front caliper hose's.. I know to use 3/16" from the fronts to the tee, but I think I need 1/4" from the master to the tee's (front and rear)? Am I correct in this thought? HELP! I shouldn't need a pro.-valve but if the line size isn't correct I am going to have troubles. I have 4 wheel disc & 11" GM brakes.
Thanks in advance
Fred
Getting ready for the next build. Got the 351W on the stand.
