Hi Ed,
No doubt March will have something for you - at a price!
If you're interested in a more budget-oriented approach, there are at least two: a Ford dealer and a wrecking yard.
You could take your present pulleys with you to a yard and get some really cheap ones, or if you can find a Ford dealer with an accommodating parts man, you can get new ones for probably less than 1/2 what March will charge you - been there done that!
By the way, my water pump pulley is slightly smaller than the crank pulley. Dunno how it is supposed to be for a small block? Hit the March web site and note their pulley dimensions - that'll give you an idea of what diameter ratios can work.
Hope this helps,
Tom
