HI RICK,
I previously pinned the gear on the dist. shaft at the correct location and the gear continued to wear. So.... I decided to pull the engine and trans and check the gear on the cam. Sure enough it has some wear. I've had no time to play the last couple weeks so everything has been sitting waiting to go back together. Spent a little time today removing gasket material from mating surfaces- loads of fun.
Thanks for the thoughts, I appreciate it, Steve
