ZZZZZ
I have a 428 in a Premier Motor Sports car. I am very pleased with both the car and the motor. The Motor is 30 over. It came off an irrigation pump in western Ks or East Colo. Chuck Nickloy suggested we use mostly Edlebrock (sp) equip. We chose the Performer RPM series for the Intake, Heads, and Cam. the engine is a low compression engine, maybe 8.5 to 9.0 to 1. Used the old dish pistons out of the field as they were good ones. That way, can use pump gas anywhere. Have a 750 holley Double pumper. Wayne Rasmussen here in KC built the motor and did a very good job (had to replace the rear main, but fixed it correctly). We put it on a bench dyno. I do not have the figures here at home to tell you the exact RPMs, but the max HP was 461 and torque at about 520. May have been 518. If you want more exact numbers let me know. We used the MSD system.
Brian
