Old 04-07-2003, 06:13 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
The accusump acts as a collector when charged and should not discharge until you loose oil pressure or you turn the valve. I suspect the valve isn't actually sealing as it should when it is charged. If that is the case the accusump is acting like a sponge, soaking oil up as well as releasing it when it isn't called for.
Many engine builders try to dissuade owners from running Accusumps for this reason. The other side of the coin is the Accusump valve can stick closed negating any potential value.. It's your call. I'm personally on the fence.. Nice product when it works.. Terribly dangerous when it doesn't..
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
