Thread: Rhoads Lifters
Old 04-09-2003, 10:19 AM
Geary L. Sarno Geary L. Sarno is offline
Cobra Make, Engine: Unique 427SC, 403 FE. Dual Quad
Default Rhoads Lifters
JoeA - Even though I've seen some bad comments about the Rhoads Lifters, I've had success with three engines that I've built. Bottom end response is excellent. At idle the Rhoads Lifters are a bit noisy sounding like a solid lifter engine at the point of needing a valve adjustment to tighten clearances. As you step into the accelerator you can feel the engine progressively coming on to the high side of the cam as the lifters pump up solid.
The engine in my personal 427SC has them. At idle my FE is pulling over 16 inches of vacuum at 950 RPM.
Contact me if questions remain. - Aggressor
