Old 04-12-2003, 05:22 PM
Ant Ant is offline
Default White stripe Toploader
Cal Metal:
Have had a look at David Kee site, the white stripe would be good if I changed final drive ratio down to 3.5, for the circuit, what I am trying to avoid is ring and pinion changes from road to track use
With the Sebring ratios of 2.13, 1.59,1.19, 1 this makes the car with 3.08 rear end gears, a 71mph first gear car @6500rpm, for road use taking off may be not a nice with a real lumpy engine!
Mind you the toploader is very strong, and I will have to compromise on what ever I use as I realise that nothing is perfect, a point on the 5 speeds is that first gear can be say 3.28 and the other three gears can be spaced between fifth for a better compromise.
What are these G-Force tranmissions like are they a straight race box with a race price ticket?
Ant
