Old 04-13-2003, 06:42 AM
TC Cobra's Avatar
TC Cobra TC Cobra is offline
Cobra Make, Engine: Classic Roadsters; 351w, Crane Cam, AFR 185's
Thanks for the response, DV. Sorry to be so vague.
I have Heidt's upper and lower control arms and Tommy's uper control arm mounting brackets (the ones that change the mounting from horizontal to vertical and allow for the use of shims for alignment)
Tommy said I can use the brackets any way they work out best as long as the taller ear was at the front. That leaves me with the choice of whether the brackets are attached with the vertical side towards the inside or outside and also which pair of holes (upper or lower) to use to mount the control arm.
Hope this helps clarify my question.
Thanks!
Dwain
