Old 04-15-2003, 11:24 AM
brandonF brandonF is offline
I've used the roto zip, it's not bad, you just go through bits like crazy, I found that an air powered hack saw worked great. For the tight areas I used a dremel /w cut off wheels, you'll also go through a lot of cut off wheels. If you torque on the wheels to much they shatter.
