Hi there Mike
Hey Mike, good to see your getting there.
Looks like i will have the 6 speed box before i come to Melbourne so as the time gets closer i will need to talk with you and make sure you are ok to help with modifiying mine the same way as yours, (I will get a shifter and all)
I wont be there till december, so i will order the shifter and make sure i have it with me when i see you.
Let me know what accesories you need for your engine as i am pretty sure i can get a flywheel and cable operated throttle body for you.
I have a 2nd hand flywheel in my shed that i probably wont be useing, (because if i get the stroker kit it comes with a flywheel).
I will be looking for a startermotor, alternator and power steering pump if i go with power steer so i will talk with other dealers to see what i can get for the 2 of us.
I also have standard commodore headers you can use to make the under car exhaust for rego.
Good luck with all the work and i will keep in touch.
Cruising in 5th
