Bill;
How are you? I've got a quick question concerning my Contemporary.
The door latch that is attached to the passenger side door opening is getting a bit loose. The fiberglass has also cracked a bit under the latch. Here is the question:
What is behind the fiberglass under the latch? Is there a steel hoop or something? The screws holding the latch seem to have been shortened so that they are only in the fiberglass. Can I drill into the structure a little bit more to put in a longer and stronger screw so I can pull the latch in tight to the frame?
Thanks, Bill.
Corey Zimmerman
