Chuck,
Did you torque the nut to specs?
The "rule of thumb" for the Dana 44 is: If you twist the pinon shaft by hand, with the axle shaft stationary, you should have less than 1/4 inch of play. If that's good and it's not leaking or making noise, you're golden.
Paul
