the tranny mount goes under the rails.
and as i am told with the lower links paralell to the ground the tranny should be just slightly higher than the differential for the driveshaft to work properly.
i used extra long 1/2 ' bolts to give myself some adjustment, but as it turned out with the flat tranny brace and tranny mount i ended up tightening them all the way up.
you can be no more than 7 degrees out, but you do not want to be level.
good luck
tom
SSSSSSSSSSSSS
