Old 04-20-2003, 05:09 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
You haven't complained about the pressure plate, so I assume it's ok. The disc is for sure what's giving you problems by giving up from the excessive heat. Organic facings coupled with high torque and a lot of slipping ensures certain failure. I've have excellent success in curing this same problem with ceramic--three puck per side--friction facings. These things love the heat and friction coefficient increases as they get hotter. One thing you've got to watch with this type of disc with mechanical linkages is the loss of free play because the facings get thicker after they are first used. Consequently, you have to readjust your clutch linkage. But if you're using a hydraulic linkage, it will self adjust.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
