thanks roscoe, you ought to be getting paid by these guys for your ringing endorsements of this product. Everybody seems to rave about this thing. The setup I ordered was $189 with the rubber boot. I don't believe it comes with a shifter and I always intended to use the bent shifter.
maybe it does come with it but I cannot recall. I looked up the SCOF technical doc but it really only tells you to peel back the carpet and look for the metric allen bolt. I have read elsewhere here that it's a good idea to use mild loctite on the bolts that secure the shifter. any other suggestions are appreciated, but I am sure I can do some more digging here to get the line by line info.
thanks
fm
