I got your email. I was thinking about the best way to solve your problem. The very best way to do this is to have someone sit in the car and jerk the steering wheel back and forth while you watch underneath. You should be able to easily detect where the lplay is, especially if it make a noise. It could be steering links tie rod ends or wheel bearings.
I had a bad problem with the end link bushings in my rack. The spherical joint wears and develops play. I was able to add shims to take the play out but after a while you have to do it again. I was able to buy a brand new steering rack on ebay, so when I have time, I'll install that and completely solve the problem.
Paul
