Thread: Any ideas?
Old 04-22-2003, 05:33 PM
DAVID GAGNARD's Avatar
Lee;
Actually the Tremec and the top loader share the same bolt pattern,but as Mr. Fixit has said there are other issues to check. The Tremec input shaft (the one that goes in the clutch/flywheel) is actually 3/4 of an inch longer than the top loader....When I put a Tremec in my 65 Mustang, I used the same bellhousing it came with for the toploader,but had to buy (in my case,make my own) a 3/4 inch thick "spacer plate" that went between the trans. and bell housing for that reason....
If possible,measure the depth of your bell housing and if possible the depth of a "factory" bell housing as well as the diameter of the hole on the back side where the trans. bolts up and it will give you an idea where you stand....
If the bell housing you have is for a toploader I do not see why it would not work with the tremec assuming you use the 3/4 inch spacer plate,but before you do anything,I would take a whole bunch of measurements to make sure before buying parts you may or may not need and parts that may or may not work....
Hope this helps some..
David
DAVID GAGNARD
