Alain:
I think what you are tring to achieve is to mount the alternator on the passenger side down low similar to the way a 289/ early 302 had them mounted in a Mustang(??) The front covers themselves will bolt to all blocks as far as I know but the water pump has evolved by adding a back plate, switching the inlet (hose) from the passenger to the driver side and consequently the bolt pattern has evolved through time as well. The parts you illustrated will mount the alternator low with the correct cover and water pump. You will need an early front cover and water pump. Check Ebay ther are normally several with pictures. Search "289 302 Ford"
Good luck
Rick
