Old 04-25-2003, 11:54 AM
SFfiredog SFfiredog is offline
Hello,
Most of the engine components for a 450 hp eng cost the same as a 550 hp engine. One area that you could save $ on is a crankshaft. The $25 to $30k engines use $2500 billet cranks.
I think I could build a 450 hp Shelby block engine using a Scat 3.98" cast crank, Eagle rods, off the shelf Probe or Ross pistons,
Edelbrock heads and intake, Erson Rocker assys, with either a hydraulic or flat tappet cam, etc. for $15,000 to $17,000, depending on options. The engine would be safe and reliable to 6000 to 6200 rpm and make an easy 450 hp, depending on cam selection and head work.
HTH,
Mike
They bend 'em, we mend 'em.
