Bob,
I can't seem to hook up the brake lights properly. Below is a picture of our brake light switch. To which spades should I attach which wire?
If I attach the wires to the middle and farthest spade, the brake lights are always on when I turn on the ignition. If I hook up any other way, the brake lights do not come on either when I turn on the ignition or depress the brake pedal.
Also, I have not yet added brake fluid. Is it necessary to have fluid in the system for the brake light switch to work properly?
Thanks,
