Cobera,
That is a pressure switch so you need fluid, brakes bled. sounds like you put the wires on the common to normally closed lug (switch closed) =lights on. Try the top and left lug (common and normally open) with fluid and it should work. The switch does not have polarity so it does not matter which color goes where.
curtis
