Old 04-27-2003, 06:41 AM
Double Venom's Avatar
Double Venom Double Venom is offline
This is fantastic! I'm getting all kinds of offers to help complete Jenny's motor via the cobra sites and e-mails. Just an update, I think Mr Viagra will be taking care of the electrical part, and Gordan has volunteered to get us a shifter. (Have to confirm this up though.)As you can tell from my original post, Mr Mustang is doing the Carb, and Weendoggy has already locked in the clutch sytem. I didn't hammer Weendoggy for the Hydraulic throw-out bearing as this alone is a bit pricey. Anyone up to supplying this?
CSX700?: I went through our "bomb room" yesterday. I knew I had some type of small block OEM bellhousing lying around somewhere! Lo and behold! I found it. It is a stock OEM '65 aluminum housing and bolts right up. I do however have no qualms at all about using your blow proof housing! I guess the question is, if you really want to donate it, then by all means I will use it. Let me look today to see if it is a 5 or 6 bolt. I honestly can't remember!
Still would like some input about the fuel pump? Electric, or should we keep it OEM with a mechanical?
If anyone is interested and can tell me how to post it, I will take a short video of installation and firing for the first time!
DV...you guys are amazing!
