Old 04-28-2003, 05:11 AM
John Poling John Poling is offline
Ron,
The seats will work just fine for you. The door panels look like they would fit depending on your door hinge bar spacing, but you would have to do some modifications to them to use your current pull cable for the latch which wouldn't be difficult. As for the dash, I am not really 100% sure as you have the sculpted sides on your dash, the cover I have is plenty wide enough with inches to cut off for mine but I don't know how much wider the material needs to be to cover yours.
If you take some measurments of the distance between your hinge bars vertically, the length/height of your door (front-rear and top-bottom) of where the panel would mount and the running width and height of your dash, I will let you know more confidently. Make sure that you follow the contuor of your dash panel when measuring.
As for the carpeting, no I don't have any.
Thank you for the compliment. Lots and lots of work aren't they?
John
