Old 04-28-2003, 09:23 AM
Seaman Seaman is offline
Cobra Make, Engine: Power Performance Body, Contemporary chassis, 427 CO, Big I/O toploader, AMP Billet rear, Trigo 6 pin
Question Contemporary Jag Rear
I tried to install the differential in the frame this weekend and ran into a little problem. My lower control arm brackets do not end up horizontal. After a little investigating, I obviously have zero degree brackets, this makes the control arms parallel to the pinnion. Can any owners tell me what the correct pinnion angle is, and then what angle the brackets need to be. I know there are zero, 3, and 6 degree brackets so I just need to pick up the correct set. I haven't used an inclinometer to check the angles, but I thought I would try here first. Thanks for the help
Dave
