Old 04-28-2003, 04:46 PM
csx700? csx700? is offline
Banned
DV
the narrow pattern mounts are nearly flush with the trans case and were usually early top loaders.the wide pattern was available usually after mid '65 and later top loaders and have mounting ears that sit away from the trans case,you will need to know which trans you have regardless of which bell housing you use,some bell housings have both patterns.the ansen that i have was actually from a tiger.............john
