David, If you want to have the headers remade I can have them done for about $350. You could also eliminate the crossover system and use standard headers without the cats. You would probably have to get an extension from the header to the sidepipe because the sidepipes you have exit closer to the body to allow the cats and pipes. Not a major problem. I may also be able to find a set of the short style header you have. Which engine do you have, Ford 302?
Don
