DV
i looked at the bell housing when i got home from work today.the bell housing is for the 6 bolt block it is presently setup for a narrow pattern trans but there is pre drilled holes for installing a wide pattern trans,the holes just need to be tapped for the mounting bolts .if you want it to install into jenny's car it's all yours,we just need to figure out the shipping (it's heavy)............john
