Hannes,
This is where a member advised me to start with the webers.
"If this car is for the street, 37mm chokes are a must; 65/120 idle/holder;
145-150 main jet; 190-200 air correction jet; F 7 etubes; 55 bypass jet
(sits in the bottom of the float chamber)."
The cam is also very important. Something about the overlap but I am not sure. I think you want to keep valve overlap on the low side with these carbs. Too much overlap and at speed you will blow raw fuel out of the carbs, that's ugly.Hopefully someone can clear this up for us. Also a good book is Weber Carbs by Pat Braden. Has a tune up section and info on all webers. Good luck and let us know how you make out, Sal.
