Old 05-01-2003, 12:24 PM
Mike I's Avatar
Mike I Mike I is offline
Cobra Make, Engine: E-M Cobra - RCR GT40
Sal is correct about the issue of cam overlap. Independent runner (IR) induction systems will always be subject to some level of reversion at wider throttle openings (fuel/air mixture spraying back out of the carb inlets), but it get's much worse as the overlap values go up. Also, stay away from split profile cams (different values for I/E). Hope this helps some.
Mike
