Old 05-02-2003, 08:20 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Similar setup. Heidts "D" uppers, RCC lowers with coil overs, Tommies upper brackets.
My alignment guy about kissed me when I installed them, and alignment hasn't budged.
Ears go in toward engine, use lower holes.
Used stock nuts to hold bracket to frame. Used longer G8 bolts to hold arm to bracket.
All 4 corners will be different and will be set by alignment shop. Use '78 MII settings, and 6 deg camber.
