Old 05-02-2003, 09:44 AM
Whaler Whaler is offline
Hi, we have all been thru this one
Simply do the math on it.
Pan capacity=? you would know
filter=? .75 liters
lines and cooler if they are the usual size and run= 1.5 liters
not showing on the stick may simply mean another liter or your stick is really off in terms of depth/length.
Have you old one to compare to??
If you can be bothered, drain the ooil now after the engine was primed and ran. see what comes out and you will know what stays in the filter cooler and lines. After an oil change.
But keep in mind what you started out with and what u will need to add for changes
Tim
