Ok, so, as I can see, I am not able to reach by goal - to pump out 300 HP with Intake+Carb+Air filter only - from an 302 SB.
Have decided to change the cam too. And head porting. If I change the cam - which one would you recommend? Duration+lift+brand. Just not to hit the pistons by valves. And with this new cam, and ported heads - probably te Intake and Carb must be sized higher?
Anyone who has converted his 302 SB this way?
